I am really new to Navision + .NET developments. If you guys can help me to solve this im really glad to you.
I have created a code unit in the Nav 2009 Classic With Microsoft SQL server. The code unit as follows:
The method is called "Initeditor()"
IF ISCLEAR(RTFAutomation) THEN
IF ISSERVICETIER THEN
result := CREATE(RTFAutomation,TRUE,TRUE);
ELSE
result := CREATE(RTFAutomation,TRUE);
This method is called by New Navision 2009 client. But when creating the Instance of automation variable the client is closed. I don’t know what is the reason.
Can Anyone give me a trick for solve this issue please…
