What is the process to update the AX license file when an ISV license is also in place?
Hello,
I have to update the AX license., however when I go to load the license file I receive a message saying the 3rd party ISV tables will be dropped. We are using TDCI BuyDesign and do not have support. Does a TDCI license need to be loaded at same time?
Does any one know this process?
~Best
Hi Girac, how did you solve this problem? I’ve just run into the same thing… My idea is manually adding ISV license codes to the file.
Actually, there is an additional dialog for confirming DB synchronization. If DB synchronization is rejected, there is time to add further license codes.
