When doing upgradition using Developer toolkit.Which code unit should i use to change database version to higher version ?
Marshal;;.j
Marshal;;.j
This is a part of the executables. It will happen as soon as you connect to the database and accept the message.
Thanks your Valuable reply reply .
Tnaks
Jerome Marshal.J
You are welcome, but please verify the solution that helped you.
