D365
I have in front of me a custom priviledge that has Action Menu Item as an entry point. That Action menu item triggers runbase class that generates records. I’m a bit surprised that on that Priviledge "Access Level "= “Unset”, but “Future Access Level” = “Delete”
As I unsderstand Future/Past/Current access level is used for the tables that are dateeffective. Therefore:
- I’m not sure how this is supposed to work with RunBase . Isn’t mainly for the forms that display dateeffective table data?
- Do you need to set “Access level” anyways if you are using any of the Date Effective Access Level setups.
Thank you!
