WebService SOAP Exception
Hello Friends,
I made asp.net application using NAV webservices. it runs fine on developement mode but when i publish this project and call by browser it gives following error :
Please Help me
The login failed when connecting to SQL Server SHARAD.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.Services.Protocols.SoapException: The login failed when connecting to SQL Server SHARAD.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[SoapException: The login failed when connecting to SQL Server SHARAD.]
System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) +734213
System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) +345
NavisionPortal.CompanyInfo.CompanyInfo_Service.ReadMultiple(CompanyInfo_Filter[] filter, String bookmarkKey, Int32 setSize) in C:\Users\SHARAD\Documents\Visual Studio 2010\Projects\NavisionPortal\NavisionPortal\Web References\CompanyInfo\Reference.cs:135
NavisionPortal.WebForm1.Page_Load(Object sender, EventArgs e) in C:\Users\SHARAD\Documents\Visual Studio 2010\Projects\NavisionPortal\NavisionPortal\WebForm1.aspx.cs:32
System.Web.UI.Control.LoadRecursive() +71
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3178
