Can anyone recomend a low-cost web-based time-sheeting solution for NAV? (interfaced to jobs module?)
I am looking for an out-of-the-box module and not custom development.
Cheers,
Dave.
Cheers,
Dave.
I found this thread on mibuso so I have a few to look at. If anyone can suggest any others I would appreciate it.
That is a very good thread [:)].
Well if the key-word is really “low-cost” then I would really basic web-solution, where the data are simply stored in a local database on the hosted web server.
And then I would create a function here, who could simply download the data to a xml or csv file and create a simple dataport into NAV.
I have seen several free (open source) solutions for this before, and if you’ll I can check my archive.
But hey, if low cost is not the only key factor, then I sure would like to recommend you this solution:
http://www.navicom.dk/NaviCom_UK/Products/Industry_Specific_Solutions/Project_Management.aspx
It’s a very good all round Project Management solution build on the job module.
I have recently developed a web interface for a project management add-on. http://dynamicsuser.net/blogs/nunomaia/archive/2007/08/14/web-services-with-nav-4-0.aspx
If you want, later I can give you detailed information about add-on.
