Washed layer in Axapta
Is there any Washed layer in Axapta ? someone asked me this question .
at the time of compare tool it shows washed layer. pls share your thoughts on this.
Regards
Nitin
It is not a layer in Ax. By using Washed in Compare you will get the deviations from the best practices.
Thanks Kranthi
will you describe little more , what dose washed in compare.
Suppose you have done some changes to an object in the VAR layer. and if you want to know the changes done are according to the best practices - you can do it with the help of compare tool(though your compiler shows them).
Select the VAR and washed and compare them - It will give you the best practice deviations.
Thank’s Kranthi.
