Hi to all,
Can anyone please tell me as to how can I create xml file from within Navsion. I searched for it and all I was able to know that it can be done via automation. But I still am not clear how to use automation to generate an xml.
regards,
Naval
For what you want to create XML file? I mean do you want to export your data in XML format or some other task?
If your NAV Version ist 4.0 or later, then you can use XMLPorts to create XML-Files.
If your Version is before that, you will have to Hard-Code the XML Structure in a File Export.
