W2KSP4 , Axapta 2.5 SP2 and Gant charts
Hello, we tested Axapta 2.5 / SP2 with Win2K SP4. Since we applied SP4 we get errors with the gant-charts. error: "fieldBackgroundColor error code 0x80010105 " did anynone experience the same problems? (Seems also to happen with WinXP…) Thx Pirmin
hi, Did u apply the Win XP Service pack also. Please try that. Also let me know. regards vaibhav pednekar
There are lots of errors in Axapta 2.5 SP2 with Win2k SP4. I don’t remember all, but we had several problems, among others I remember that the help system didn’t work correctly. I didn’t try gant-charts in particular, but I’m willing to bet that the solution is the same. What you need is a “kernel update” for your Axapta 2.5 SP2. That’s an updated .exe file (and a couple of .dll’s), which deals with incompabilities with Win2k SP4. Ask your dealer for this kernel update, and I bet things will work better.
Hi… just to share the “very quick and very dirty solution” [}:)]. We replaced the hhctr.ocx in \winnt\system32 with an older version. Seems to work. Anyway, we know that this is a absolutely NOT recommended solution !!! (But we didn’t have the time to test the AX2.5 / SP2 hotfixes. So if you face the same problems, pls try to do it the “offical” way !! Ask your MBS partner for the appropriat Hotfixes for Axapta ! Thx … Pirmin
