Void purchase journal in different period
How do you void a purchase journal in a different period than it was originally posted in and so the vendor shows the invoice is not open? From the vendor > ledger entries screen, the reverse transaction entries will not work because we need to post in a different period.
You cannot change the date. What we’ve done in the past is issue a CM using the date you need and then apply the CM to the invoice.
