Visual Foxpro and C/front
Has anyone got some experience with visual foxpro and cfront? I can open the Navision Database and login to it but I have some problems with the opentable function. The message is Type mismatch. Can any of you experts give me some advise? Kind regards, Jacco Dijkslag
Type of variable assigned for navision object (table, record, field) must be Integer,Long or equivalent. Business Applications Programmer Sertified Navision Developer SIA “Sintegra” Latvia
Thanks for the reply. So I thought that if I used the command opentable(1,37) then I must be able to open table with ID 37. Can you maybe tell me more about the handle? I don’t know exactly what the handle means.
Handle is unique identifier, which points to some object. Absolutey like “hWnd” property in Windows’ window. It’s only object’s identifier (reference). Business Applications Programmer Sertified Navision Developer SIA “Sintegra” Latvia
Hello Jacco,
Still at trying to get Foxpro do work with Navision?
I see you attempt to use C/Front now. (Tedious, can’t use the dutch captions)
How far did you get?
