There are plenty of places which shows customer name in ‘Aged Accounts Receivable’ report. Which part do you want to hide/show according to the check box? Screen short of report sections will be more helpful.
Step 1- First you have to create a Boolean type global variable.
Step 2- Insert checkbox into option tab of request page of the report.
Step 3- Bind the global variable to check box.(through SourceExpr property of check box)
Step 4- Find the correct data item to write the code. For that you have to check report sections. By referring that you can identify how the report is designed and what data is displaying. According to Agee Accounts Receivable report I understand you can use ‘OnAfterGetRecord()’ of Customer data item.
Step 5- End of the trigger you can write the code to make visible/invisible of customer name according to your checkbox.
eg. IF = FALSE THEN
Customer.Name := ’ ';
To do this you need to have basic knowledge on MS Dynamics NAV report development. I recommend you to read training manual.
It is not in the report request page. You have to go to report designer as follows. Then select the data item you want and press ‘C/AL Code (F9)’ to go to it’s C/L code.
Hay I strongly recommend you to read the training manual to start. Otherwise you will be in a problem.
This is my first C/AL code and it works fine…just because of your help…thanks again…
Yes…you re exactly right…I am learning it now…But I couldn’t find a proper training manual. Can you please tell me a good training manual for a beginner.
