My version 4 installation (single client) is crashing periodically. The event viewer gives me the following information: “The description for Event ID ( 1000 ) in Source ( Microsoft Business Solutions-Navision ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: fin.exe, 4.0.0.19365, 41486f00, fin.exe, 4.0.0.19365, 41486f00, 0, 000b3f02.” Anyone seen this before? Thanks
For information: This problem is a known issue which will be fixed in Hotfix 1.
Paul, Does MS have any way around this issue today? Hotfix 1 is still months away. Thanks…
Sorry, not to my knowledge. However, if you are experiencing the problem frequently then I suggest you contact your solution provider or Microsoft (if you are a solution provider) to get a workaround.
Your error message indicates that you are at build 19365… there is a later build available(20942) if you know the magic words. Take a look at this: http://www.mbsonline.org/forum/topic.asp?TOPIC_ID=13228 Don’t know if it will solve your problem, but it might be worth a try.
Thanks, yes it has. Build 20942 works fine.
