Vendor workflow multilevel approval setup
Hi
Requirement is related to Customer and Vendor creation thru Work flow. When a customer of vendor is submitted should be approved by employees of two groups. One employee each off Group 1 and Two Please, How to give user names in Workflow i tried by using job title but its not flowing its throwing error and got stopped. Requirement is 1st level user A & B are there either A or B has to approve, and in 2nd level C,D & E are there either C, D, or E has to approve advice
Regards Ravish
Refer the below blog
http://daxing2012.wordpress.com/2013/04/17/using-the-managerial-hierarchy-option-in-workflows/
Hope it will solve your problem.
Prabu
Hi Prabu
I have created the position hierarchy as explained in the link which you have given and configured the work flow as explained in the link but am getting this error
Stopped (error): X++ Exception: The hierarchy provider did not return any users.
at SysWorkflowHierarchyProvider-resolve
SysWorkflowHierarchyProvider-resolveHierarchy
SysWorkflowQueue-resume
SysWorkflowMessageQueueManager-executeTask
SysWorkflowMessageQueueManager-run
Position hierarchy i have given as Organisation ← A ← B ← C
and stop condition is set to “stop where employee.Line manager level =2 once vendor is created and submitted its going to C. C approves it then its not going to B at this point this error is coming
Please advise
Regards
Ravish
Hi
I’m sorry. I’m from functional side. May be we can ask for the help of Technical experts forum to solve your problem.
Prabu
Hi
By checking the forum I found the same error was reported and the solution given
Please check the link http://dynamicsuser.net/forums/t/69908.aspx
Prabu
Hi Prabhu
Thanks its working
Regards
Ravish
Hi
Fine. Please make Verify Solution this thread so that it will be helpful for others looking for solutions.
Prabu
