Hello,
In ax 2012 i want to set vendor payment approval. Can anyone guide me how can i set that approval to vendor payment.
Chetan
Hello,
Chetan
You can use default setup of Approval Process in Journals. GL > Setup > Journal Names > General Tab > Activate Approval Process and select the User Group to authorised for approval.
Alternatively you can use Workflow for Approval Process
Hi sachin
I have used the default setup but it is not working
Hi Chetan,
Are you using Workflow and default setup together? Both will not work together.
After activation did you try creating New Jounrals?
It will only work for newly created Journals not for already created Journals
Regards
Chetan you have marked the post as resolved, so generally people would not look at it.
Adam What can i do. Can i keep it as unsolved…
