I am hoping you might be able to help me identify the Vendor Ledger Entry table in Navision.
I am trying to download the data from the Vendor Ledger Entry into my excel spreadsheet, but am not sure what the name is. I have successfully connected to the database and can see the tables but can’t identify the table I am looking for,
On the SQL server tables are named after this convention:
COMPANYNAME$TABLENAME
So in your case (if you want the vendor ledger entries from a company called CRONUS) the tabelname to look for is:
CRONUS$Vendor Ledger Entry
NOTE!
If you use ODBC you can’t export values from flowfields, you have to export the data from the underlying table.
So if you want Remaining Amount, you have to export the appropriate “Detailed Vendor Ledg. Entry” records, and do the calculation in Excel afterwards.
(Also note that some signs are changed on the sql-server, so “Detailed Vendor Ledg. Entry” would be named like this on the sql-server:
CRONUS$Detailed Vendor Ledg_ Entry)
