Hello expert,
i am a beginner to Navision.
How i can show Applied to Document No. filed on the report 304 - Vendor - Detail Trial Balance?
i found the filed already existed but it seems doesn’t show anything for this filed
Thanks so much
Ant
Hello expert,
Thanks so much
Ant
in vendor ledger entry section, you have: “applies-to ID”, “applying entry”, “applies-to doc. type” and “applies-to doc. no.” fields.
in detailed vendor ledger entry section, you have: “Applied Vend. Ledger Entry No.”
now, it’s your call which one you want to use, and make it appear in the report by adding textbox(es) with sourcecode = any fields that you require as above.
Thanks for your replied.
i have checked in vendor ledger entry, there’s no data was filled in to applies-to ID or applies-to doc. no. fields.
but the data was filled in to closed by Entry No. field.
so how i could make Applied to document No appears on report bases on Entry No. ?
