How can I say to my report 206, to print vat information even if VATAmountLine.“VAT Amount” is 0?
The section VATCounter is not printed when .“VAT Amount” is 0, but I whant to. How can I do it?
Do you see this code in the VATCounter OnPreData Item Triger.
IF VATAmountLine.GetTotalVATAmount = 0 THEN
CurrReport.BREAK;
Comment this out so it looks like ths:
// IF VATAmountLine.GetTotalVATAmount = 0 THEN
// CurrReport.BREAK;
Is that OK?
No :_(
That t was my first option, but does not solved the problem.
Hi
Any Idear to this problem?
I really need to show in report 206 the Vat Amount Specification line, when Vat % = 0, Line Amount = 0 and Vat Amount is 0 too.
If I have 2 lines in my invoice, one with Vat % = 20 and other with Vat % = 0, I need Both Vat Amount Specification lines in my report.
How can I do it?
Thanks a lot
Hy
Any Idear ???
luana,
Please don’t cross post (I joined your 2 threads) - that’s first. Second - don’t be so impatient, if you need IMMEDIATE answer, call MS paid support or your Partner.
Returning to your question - if BOTH LineAmt and VAT Amt are zero - what does such line do in an Invoice?
In case when LineAmt # zero, but VAT = zero, VAT section is printed as you wish, showing a line 0.00 VAT for VAT Identifier “NOVAT” - tested it in Cronus v5 just for curiosity. So, problem is seemingly in your Invoce itself or VAT settings, not in R206.
Hy Modris, you are right, some times I am Very impatient.
Even if LineAmt and VAT Amt are zero, I still have VATAmountLine.“VAT Base” <> 0, so I need to list in my report invoice this information:
VATAmountLine.“VAT %” VATAmountLine.“VAT Amount” VATAmountLine.“VAT Base”
0% 0,00 Euros 10,00 Euros.
If I have 2 lines in my body invoice, with <> vat %, one of them = 0 them I must have 2 lines in VAT Amount Specification
Do you see my problem
Thanks a lot
