Do you know how, make appear VAT amount in the printed invoice?
Display Tax Amount field in your report which is available on Sales Invoice Line table.
Hi Amol, thanks for the answer. Now If I want to show the VAT Amount when in the lines of the invoce, how I can do?
Hi, open your report in Design mode. Open up the Sections area of your report and add Text Box from your toolbox to the spot where you want to display the VAT Amount. Set your SourceExpr on the properties of the text box to “VAT Amount”. Save and run your report
Take a look at your reports in design mode and you can see plenty of examples of how Text Boxes work in the report. The C/Side reference guide should help you out as well. Good luck!
Hi, I went to TOOLS > DESIGNER > REPORT > DESIGN and then I choose the Toolbox? but which is the option in the toolbox to add the VAT Amount?
Add the text field to the sections area first, and then modify the properties of the text field to reflect the VAT Amount
Sorry how can I add the text field to the sections area ?
Open the section designer of report
Go to View Menu → Click on ToolBox
Click on Textbox Icon and then place in section where you want
Now click on Textbox and Press Shift+F4 .It will open properties of textbox
Search for property called sourceexpr and select field which you desire in this proprerty
I suggest you to read some basic technical documents and contact your partner also…
thank you amol, was very clear your answer.
Don’t forget to
the post(s) that solved your problem!
Hi Amol,
Thanks for the help
hi…need to study basic nav report
Hi Packiya, could you advice me a good book to study the reports?
Read Application Designer Guide and Introduction to C/AL manuals which will clear your basic concept.
Hi amol,
I found by internet the PDF: Application Designer’s Guide - Microsoft Download Center
Microsoft Dynamic NAV 5.0
did you reffer to this manual?
Yes
