hi Guys, i have just strated working with navision. but can you guys help me little ? i want to pass variable between two forms. how do i do that ? i know lookup and form.runmodal. any other way by which i can pass the global variable of one form to another. Hemang Naik Senior Software Engineer
- create a function in your Dest.-Form. 2. configure this function with parameters 3. within the function pass the given parameters to globals in your Dest.-Form 4. create a var of type form in your Source-form that points to your Dest.-Form 5. from the Source-form first call the function that passes the parameters and then call the form itself … myform.myfunction(parm1,parm2); myform.run; BTW - this is the forum for the old character-based version (N3) … Better post questions about Financials to the Financials-forums.
