Dear sir
i am new in navision. please tell me about working of validate function in navision.
msdn.microsoft.com/…/dd338618.aspx
navisionworld.blogspot.in/…/testfield-validate-functions.html
VALIDATE calls the OnValidate trigger of a field.
Validate is used when you want to assign a value to a field which exists in a table and also you want to execute the code which is there in this field’s OnValidate() trigger.
For eg: I want to change the value of Type & No. field in a Sales Line, My code might be like,
IF SalesLine.GET(“Document Type” , “Document No.” , “Line No.”) THEN BEGIN
SalesLine.VALIDATE(Type , SalesLine.Type::Item);
SalesLine.VALIDATE(“No.” , ‘ABC001’);
SalesLine.MODIFY;
END;
This code will change the values of Type and No. field to Item & ABC001 respectively. And it will also execute the code written in OnValidate triggers of these to fields.
And I would suggest you to read the ADG and NAV technical pdf’s to start learning from beginner level in NAV.
Hi
You can look at this link to understand
