Has anyone tried to use a RapidStart Configuration Package import into the User Group table (9000) and User Group Permission Set Table (9003)? I found that for the User Group Permission Set table, field #4 Role Name does not appear in the Configuration Package field list. I assumed that would be OK because it would probably be validated and populated through some code, however that was not the case. The Role Name for every row was empty. I’m not sure if this will be an issue. If I try to validate a specific row by using the drop-down look-up to re-enter and validate a Role ID , then all of the Role Name s from that point down get the same value.
