Hey guys,
not sure what to write in the subject line, very complicated yet simple problem…
Current scenario: we are installing an add on which will allow us to print to pdf and directly have the document attached to the body of a message. This add on works from the computers , but on the most important client (doesn’t luck always work this way?) it is not working.
The client is running windows 2003 and is a Terminal server. We have office 2010 for terminal server installed on it. We never had a problem with using the features of Office on this client (which happens to be a server).
Now when we do try to execute the add-on , we get this error:
"this message is for C/AL programmers:
Could not create an instance of the OLE control or Automation server identified by
GUID={03BC4F50-2ABB-48B3-B2A6-3F08EB1D013E} 1.7:{F3B45F48-1F4A-40C9-8DE6-5CC377BF4F82}:“NS Outlook Synchronization Handler”.OSendMail.
Check that the OLE control or Automation is correctly installed and registered"
Our solution provider gave us specific DLL files to register, we did that , but it did not work… same issue…
Anyone knows of any compatibility issues between this version of Office (it is 32 bit mind you) and Navsion 2009 R2 ?
the .xml files are in the appdata folder of the userprofiles …
oh and we are using the Classic client currently…
