Can i use an item which is not entered in item master card
My actual tequirement is : My client use an item X as one of the items in manufacturing an item Y so he dont want to maintain that item X in master
Is it possible ??
Is it possible ??
Does your customer need to know how many of item x are on stock in order to plan requirements for replenishment for producing item Y ?
If so - you do need the item. If you do not care - or you are maintaining the requirements manually then you do not need to maintain the item card.
But in this case you need to post the costs for item X manually in general ledger directly.
Thank u very much
Yasho, please click the “Verify Solution” button in the post which helped you to solve your problem or answer your question. This will earn you points and credit the poster of the answer and shows other people that your problem is solved/question is answered.
