Dear All,
I am creating one DLL in Vb.net framework which access custtable information from axpata 3.0,
sqlstr = “select * from %1 where %1.accountnum == ‘4000’”…using this query we get data from single table i.e custtable.
But i want to retrieve information from two tables as we do in axapta with the query like “select custtable where custtable.accountnum == custtrans.accountnum”.
below is the source code for the DLL, which runs perfectly and gets output, but when i tried with two tables i am not getting any output .
anybody tell me how do i write the syntax retrieve data from two tables with joins in vb.net frame work using IAxapta interfaces.
Public Function fun_table()
Dim Axapta As Object
Dim Myrecord As Object
Dim Myrecord1 As Object
Dim myrecord2 As Object
Dim sqlstr As String
Axapta = CreateObject(“AxaptaCOMConnector.Axapta”)
Axapta.Logon()
Myrecord = Axapta.createrecord(“Mytable”)
Myrecord1 = Axapta.createrecord(“custtable”)
myrecord2 = Axapta.createrecord(“custtrans”)
‘’ Myrecord1.field(“purchid”) = “00008_049”
MsgBox(sqlstr)
Axapta.executestmt(sqlstr, Myrecord1)
While Myrecord1.found
MsgBox(Myrecord1.field(“accountnum”))
Myrecord.field(“name”) = Myrecord1.field(“accountnum”)
Myrecord.field(“address”) = Myrecord1.field(“name”)
Myrecord.insert()
Myrecord1.next()
End While
MsgBox(“def”)
End Function
shabeer.
