Hi all! Does anybody use User Portal? I tried to set it up, but all xml’s had 0-length after installation. [:(]
Hi … The .xml files in the C:\Inetpub\wwwroot\Dashboards\Forms***\ should be of size zero, but not in the C:\Inetpub\wwwroot\NSWebParts folder. Is that the case? Br, Gulli
Hi, Gulli! Thank you for reply and help. Yes, I suppose you are right. Then I don’t know, what is a trouble… I followed all instructions given in a guide, but when i start it, i have an error in every web-part: Script Execution Error: Object Reqiered or smth like that. And one more question: Should The .xml files in the C:\Inetpub\wwwroot\Dashboards\Parts be of size zero too? Dmitry
Yes all of those files should be 0 bytes. There are extended attributes associated with those files that contain more information - such as refresh rate and so on. Django
