Dear Experts,
We wish to set user wise “recording File path” for each user in AX 2012 for Task recorder. but it seems, the recording path is set for all users at a time and not individual paths for individual user.
Request help in configuring the task recorder for individual user.
Regards
Hello,
Once the user records steps using Task recorder, the tasks will be saved in the Recorded tasks. And then user generates the document by giving the Document type, Template path which is dynamic.
Ask the particular user to specify individual path. And other users to give other paths accordingly. What is the problem here?
Hi Kiran,
Thanks for the quick response, but the problem is, whenever an user is specifying his individual path, the recording pah gets changed globally for all the users. it is not user specific
Hi Kiran,
Thanks for the quick response, but the problem is, whenerver an user is specifying his individual path, the recording pah gets changed globaly for all the users. it is not user specific
Globally means where? How you are able to see this?
globally means, if ia am changing the recording path for an user, it gets changed for other users too
I am sorry but we specify the path while document generation right? It is dynamic as far as I know so every time you need to give path for every user. Correct me if am wrong!
