USER ID
Dear Friends,
I had one new issue.ie When we opens our user id in an particular system we can’t see any functions in it.again we need to goto–>tools–>navigation pane designer–>then we want to press @ esc button…then it shows all functions like finance management,purchase…etc.
but we can open the same id in other system & it was opens normally.
kindly help me to resolve this issue.& try to give me solution why it happens in particular system.
Welcome to DUG
Did you try to copy the ZUP file from the system working to not working for the particular user?
you can get the ZUP file from below path in Win7
C:\Users<userid>\AppData\Roaming
Or you can simply delete the file from not working system also…
thanks a lot for ur suggestion.
actually i tried to find the zup file but it couldn’t find the path …now i will check as you said…and thanks again…
Thanks a lot for your valuable information…
I don’t know to path to find the zup file…now i will check as per your info.
Thanks Again…[:)]
