Hi Vinay Singh,
After trying all of those steps, I found these 2 cases of error on executing SSRS reports.
- When I logged on AX2009 client side and called SSRS reports by the Administrator, the report screen was blank and noticed me to add trust sites but I cannot add it because of the URL textbox is greyed out.
When I clicked close on trust site pop-up, on the report screen parameters are shown but greyed out and this message was appear on the top of screen parameters
"Browser settings prevent scripts from running on this report. To view this report without scripts, click here"
and when I clicked on the link ‘click here’ this error would appear.
"This report requires a default or user-defined value for the report parameter ‘AX_CompanyName’. To run or subscribe to this report, you must provide a parameter value. (rsReportParameterValueNotSet) Get Online Help"
and this is reporting server log information.
library!ReportServer_0-4!1a78!05/25/2011-10:03:13:: Call to GetReportParametersAction(/Dynamics/en-US/HTAS_Fuu.MSTT_OT10LogisticCost.LogisticCost).
library!ReportServer_0-4!e3c!05/25/2011-10:05:03:: i INFO: RenderForNewSession(’/Dynamics/en-US/HTAS_Fuu.MSTT_OT10LogisticCost.LogisticCost’)
library!ReportServer_0-4!e3c!05/25/2011-10:05:03:: e ERROR: Throwing Microsoft.ReportingServices.Diagnostics.Utilities.ReportParameterValueNotSetException: , Microsoft.ReportingServices.Diagnostics.Utilities.ReportParameterValueNotSetException: This report requires a default or user-defined value for the report parameter ‘AX_CompanyName’. To run or subscribe to this report, you must provide a parameter value.;
webserver!ReportServer_0-4!e3c!05/25/2011-10:05:03:: e ERROR: Reporting Services error Microsoft.ReportingServices.Diagnostics.Utilities.RSException: This report requires a default or user-defined value for the report parameter ‘AX_CompanyName’. To run or subscribe to this report, you must provide a parameter value. —> Microsoft.ReportingServices.Diagnostics.Utilities.ReportParameterValueNotSetException: This report requires a default or user-defined value for the report parameter ‘AX_CompanyName’. To run or subscribe to this report, you must provide a parameter value.
at Microsoft.ReportingServices.ReportProcessing.ParameterInfoCollection.ThrowIfNotValid()
at Microsoft.ReportingServices.Library.RSServiceDataProvider.GetParameters(ClientRequest session, CatalogItemContext reportContext)
at Microsoft.ReportingServices.Library.RenderForNewSession.GetReportParameters()
at Microsoft.ReportingServices.Library.RenderForNewSession.GetReportMetadata()
at Microsoft.ReportingServices.Library.RenderForNewSession.get_ExecuteExistingSnapshot()
at Microsoft.ReportingServices.Library.RenderForNewSession.GetExecutionStrategy()
at Microsoft.ReportingServices.Library.ReportExecutionBase.InternalExecuteReport()
at Microsoft.ReportingServices.Library.ReportExecutionBase.Execute()
at Microsoft.ReportingServices.Diagnostics.CancelablePhaseBase.ExecuteWrapper()
— End of inner exception stack trace —
at Microsoft.ReportingServices.Library.ExecutionDisposerProxy.ExecuteReport()
at Microsoft.ReportingServices.Library.RenderReportAction.PerformExecution()
at Microsoft.ReportingServices.Library.RenderReportAction.Render()
at Microsoft.ReportingServices.WebServer.ReportServiceHttpHandler.RenderReport()
at Microsoft.ReportingServices.WebServer.ReportServiceHttpHandler.DoStreamedOperation(StreamedOperation operation)
at Microsoft.ReportingServices.WebServer.ReportServiceHttpHandler.RenderPageContent()
at Microsoft.ReportingServices.WebServer.ReportServiceHttpHandler.RenderPage()
library!WindowsService_0!da8!05/25/2011-10:05:05:: i INFO: Call to CleanBatch()
library!WindowsService_0!da8!05/25/2011-10:05:05:: i INFO: Cleaned 0 batch records, 0 policies, 0 sessions, 0 cache entries, 0 snapshots, 0 chunks, 0 running jobs, 0 persisted streams, 0 segments, 0 segment mappings, 0 edit sessions.
library!WindowsService_0!da8!05/25/2011-10:05:05:: i INFO: Call to CleanBatch() ends
- The users which is not in admin group cannot call the SSRS reports because Report Server URL is not available to them and show the error below.
"SRSReportView error id 2: Cannot read information from the report server. Is the report manager URL correct?"
I have already confirmed the Report Server URL for those groups from administration >> setup >> business analysis >> reporting services >> reporting server and it was a correct path. Are there any settings which I miss for group permissions control to see a report URL?
Thank you very much.
