I have a problem of using table field names dynamically.
I need to put a SETRANGE to a table. Filtering fields are in another table.
I can take them into variables. eg. Variable1 and Variable2.
Can I put SETRANGE(Variable1,Table.Variable2) in this way.
I know, It is not working. but if there is any possibility of doing something like this, Plz anwer.
You’ll need to use RecordRef and not Record variables. With RecordRef you can access the field numbers and field names. You can then take that and use a FieldRef to set your filters. You can find examples of both all over the forums.
