Upload of per-tenant extensions is not supported for your system configuration
Hi guys!
Does anyone have an idea what to do with the error “Upload of per-tenant extensions is not supported for your system configuration.” while uploading PTE in Docker container BC sandbox.
It can be installed by PowerShell and Publish-BcContainerApp.
Thanks.
You’ve answered yourself: you have to use PowerShell to publish and install extensions. In Docker, a Sandbox works similar in some ways to On Premise and this is one of them.
Welcome to the community! The error message tells you what is wrong, you will have to use PowerShell. Here is a BCContainerHelper cheat sheet that will give you the command required to install the PTE:
