Create a Navision 4SP2 full backup2, Open Navision 4SP2 SQL Client3, Create a new test database4, Restore the backup5, Uninstall Navision 4SP2 on the pc6, Install Navision 4 SP3 on the pc7, Open Navision 4Sp3 SQL Client8, Open the new test database Message “Do you want to convert the database?”
9, Click Yes, The database is converted to 4 SP3.
Open the navision and change security to ’ Standard’ and untick back ’ a single user’
after click OK then the screen is when blank.
so basically I try to open it again…
there is an error message says:
" The extended stored procedure xp_ndo_enumusersids in the library file xp_ndo. dll is not available on the msNAVTST1 server.
Untill the procedure and libary have been added. It will not be possible to connect to this server from Micro Bus Soil Na wuth window authentication, but you will be able to connect with DB server authentication. "
I have checked my server has xp_ndo_x64.dll and we don’t have any problem with window authentication in SP 2.
I ask my vendor and he said that I should try in different test server. and later on in live …I should ask their reps to do it.
