Upgrade to 25.2 - Review entry
Hello, we would like to upgrade to version 25.2 of Business Central. We are currently on version 24.5. We have noticed that the functionality for matching entries will be removed with the update, which will result in the unmatching of all general ledger entries. How have you managed this impact? Do you have any solutions to avoid having to manually re-match the accounts for the accountants?
Hi Stanley.
Can you elaborate on what “matching” functionality you’re referring to? I have updated to 25.2 and haven’t noticed any issues to date but I’m not sure what exactly you’re referring to.
Kristen
Hi Carole,
Yes, this is a known change in 25.2. We usually test the upgrade in a sandbox, review the G/L impact, and use reference reports or a small extension to reduce manual re-matching after go-live.
We’ve supported several Business Central upgrades (including real estate customers), and early planning helps avoid a lot of cleanup. Happy to help if needed.
E: Hardik.gupta@allgrowtech.com
Hi @Stanley_CAROLE
Have you got this sorted out? Or still stuck at the same stage?
