hii,
how can i Upgrade the database version from one build version to another build version in nav 2013 r2?
hii,
Hi.
First of all, what is your role … a customer, NAV reseller, NAV contractor?
If you are a customer, this should be handled by your NAV partner/reseller. However if you are a NAV reseller or NAV contractor, links like the following on the Microsoft’s MSDN should help …
msdn.microsoft.com/…/dn271649(v=nav.71).aspx
Also if you are a partner, check partner source.
Check on the partner source a page on How to install a MS Dynamics NAV 2013 R2 cumulative update.
Ok.thanks…
