Hello,
I am trying to upgrade a Business Central 14 (BC14) database to Business Central 24 (BC24).
When I run the following command in the BC Admin Shell:
Invoke-NAVApplicationDatabaseConversion -DatabaseServer $DatabaseServer -DatabaseName $DatabaseName
I always get this error:
The database create operation failed due to the following error returned by SQL Server:
Cannot find either column "dbo" or the user-defined function or aggregate "dbo.PteIsolation_ConvertScopeAndTenantIdComboToPublishedAsField", or the name is ambiguous.
I tried:
Going directly from BC14 → BC24
Going step-by-step (BC14 → BC19 → BC23 → BC24)
Always using the matching Admin Shell for the target version
Restoring the BC14 database fresh before each attempt
But the same error appears every time.
Has anyone encountered this issue before?
Any help or guidance would be much appreciated.
Thanks!
Yes, we’ve seen this error before during older BC upgrades. It’s usually not an upgrade-path issue, but a platform dependency problem.
What’s happening is that newer BC versions expect the function
dbo.PteIsolation_ConvertScopeAndTenantIdComboToPublishedAsField, which does not exist in a BC14 database. When the conversion runs, it looks for this function and fails.
What has worked in real cases:
Start from a clean BC14 backup (no failed conversions reused)
Make sure the database is clean: no old test companies, no partial upgrades, no extensions published
Run the database conversion first using a supported intermediate platform (BC19 or BC20), then move forward
Keep all extensions out until after the database conversion is fully completed
Avoid reusing a database where the conversion has already failed once
We resolved this exact error last year for a customer by restoring a fresh BC14 backup and converting it first on an intermediate version before continuing. It’s a platform-level issue, not a data issue.
We’re a Microsoft partner and have been handling Business Central and NAV upgrades and migrations for more than a decade, so if you need help reviewing or executing this upgrade, we’d be happy to support you.
Hi @kemp1445
Have you got this issue sorted, or is there something we can help?
Seems some custom process is preventing this seems.
Did you force the process somewhere in between or it accidently stopped?
Try a fresh conversion, that’s the best way out attempt.
