I have a Requirement and is Urgent .Pls Help me out.
I Have a lookup (Say in Form A )which will be showing the vacant RoomIds from Another form(Say Form B).Here Status is an Enum Whose elements are Status::(Vacant , reserved,occupied).My problem is that when i use one room id in Form A and for the next Record also it is showing the RoomID which we used previously.Here i am facing challenge in updating particular RoomID Status in Form B to occupied. Pls help out in updating status of particular room id used in Form A i.e updating Staus in FormB, SO that we ill get the roomid in Form A which are vacant.
Hii Kranthi Here is my Chaalenge.Pls Suggest me abt the Solution.
I have Two Forms in which RoomNo is Common.In FormA i have one more field Status of type Enum with elements(Vacant,Reserved, Occupied).In FormB i have a look up form RoomNo which will be showing the RoomNo’s which are vacant(as in FormA).Now when we create a new record and take one RoomNo which is Vacant and for the next record also in lookup i am getting RoomNo which we took earlier.Here my Challenge is how to update FormA Status as Reserved for the RoomNo which we are using in FormB.
I would suggest to update the status by overriding the modified field of room id bt writing a select query or find method based on room id selection from form A.
