Very simple situation:
I have one form, one datasource and a method on the form formDatasource.modified(). So I’ve overriden the method modified() on the form datasource. I’m trying to update one field of this datasource table and then call some method:
MyTable.Completed = NoYes::Yes;
method(…);
Method checks values in the table but does a mistake when reading the value of the field I updated. So basically the method() was ‘too fast’ after inserting the value in the table so it reads the old value of the field. My question is what to use between those two lines? research() is working, executeQuery() is working, updating datasource and rereading it is also working but what’s the best practice? Do I use ttscommit here? Is this even good practice to update field value from formDatasource.modified()? I need your help. Thank you in advance.
