update statement in AOT
Hello everyone,
I’m trying to update a record in the AOT. When I run the statement below I receive the following error.
Update purchreqtable
set ORIGINATOR =‘5637164826’
where purchreqid = ‘015013’
Hello Carlos, I guess you wrote the SQL statement in an X++ job, right? In fact, X++ is a language that you probably want to learn a little bit, the grammar is different from pure SQL clause. Do you have an AX developer in office to help you?
If you are using bulk records to update, use Update_recordset
Update_recordset purchreqtable
setting ORIGINATOR =‘5637164826’
where purchreqid = ‘015013’;
Else, use a normal update
ttsbegin;
select forupdate purchreqtable where purchreqtable .purchreqid = ‘015013’;
purchreqtable .ORIGINATOR =‘5637164826’;
purchreqtable .update();
ttscommit;
Your trying to do Update u test that code in Job with ur purchreqid if that executed successfully ur SQL statement is correct.
then u implemented to ur real time ticket
