Update line values on sales quote whenever header is updated
Hello,
When i change the dimensions or sales tax on sales quotation header and if i switch to lines, then I will get a prompt(salesquotationlineprompt) asking whether to update dimension or sales tax even on lines. So here basically my client want me to have the check boxes checked by default whenever this prompt opens. I tried debugging the class sales quotation line to prompt to find where these check boxes coded,but still no luck at this point. So can anybody please guide me with this?
Thanks for your help…
Which version of AX are you talking about? Please always attach a tag with your version (such as AX 2012) when creating a new thread.
sorry Martin…The version is AX 2012 R3 cu11
If SalesQuotationLinePrompt is a form, it doesn’t exist in my AX 2012 application, so I can’t analyze it. Put a breakpoint to init(), for example, and look at the call stack.
Hi dasaradh
I think the form (salesquotationlineprompt) that you said is client customized form. Martin is correct you need to breakpoint the init() method to know the exactly form does. Is it possible to take a screenshot of the said form(salesquotationlineprompt).
Br
Portia
I think he is talking about \Classes\SalesQuotationToLineUpdatePrompt
The fields are added to the dialog here,
\Classes\SalesPurchTableToLineUpdatePrompt\dialog
yes, you are right Kranthi… Thanks for your info. It did work for me
