Update AX 2012 R3 CU8
Hi guys
While Updating Ax 2012 R3 CU8, I’m not able to select the component from the Wizard but i have completed all the perquisite. any one help me regarding same.
I have attached the screen shot for the wizard
What version are you trying to upgrade and how exactly are you doing it?
hi martin
I have upgrade from AX 2012 R3 RTM to CU8,
I have completed update for CU8 and the Kernel build version has been upgraded to 6.3.1000.309, the Application build version has to 6.3.1000.473.
I searched internet to check this version has 6.3.1000.437 but i want to clarification regarding same.
Please make sure the build and application version for Ax 2012 R3 CU8
Regards
Syed Abuthahir
Why didn’t you explain it in your original question? You didn’t mention anything like that there!
Let me quote Why is my Kernel build version not changing after installing CU-8 or the latest binary hotfix? from the Microsoft Dynamics AX Support blog. I assume you’re talking about the same problem. Note that I found it simply by putting “6.3.1000.437” to a search engine - that’s something you should be able to do by yourself.
Scenario:
You have downloaded the CU-8 hotfix from partnersource/customersource and/or are using the LCS Update installer to download and install CU-8 on your AX 2012 R3 RTM.
You have completed the install and been through the software update checklist.
Later you run AX client and click on Help > About, and notice that the Kernel build version has not been upgraded to 6.3.1000.309, but the Application build version has to 6.3.1000.437.
Note: you will also get the similar issues if you instead downloaded the very latest Kernel build 6.3.1000.x and were trying to install this on a system that has Kernel build 6.3.164.x
Why?
There is a change in the pre-requirements and the update process is halted due to that.
For example, if you have an older version of the Report Viewer 2012 installed and/or AX Visual Studio Tool (for Visual studio 2010) installed on the system then axupdate will not allow you to update the AOS, Client, Components and Setup Support Files components. Also if you have Retail binary components installed, they will fail to upgrade because the AOS components fail to be updated.
Resolution:
To successfully upgrade the kernel you need to upgrade to the latest Report Viewer 2012 and remove the AX Visual Studio Tools if they are installed. CU-8 or later binary now supports the new Visual Studio 2013 Dev Tools instead.
