When i want to use settlement button on custTrans form, i’ve got this error message “Unsupported data source used for PositionToRecord or PositionToRecordByValue. Unable to execute fallback logic to find record”.
I found some topics on the subject talking about and explaining that the new run method used on custOpenTrans form above don’t allow to use temporary or views as datasources in form extension :
public void run()
super();
if (custTransOriginator)
custTrans_DS.positionToRecordByValue(fieldnum(CustTrans,RecId), int642Str(custTransOriginator.RecId));
First question is it correct ?
Secondly how could i fix that ?
I have to add informations, i’m using DefaultDimensionView in custOpenTrans form extension that i need for that event class method :
[FormDataSourceEventHandler(formDataSourceStr(CustOpenTrans, DefaultDimensionView), FormDataSourceEventType::Initialized), SuppressBPWarning('BPParameterNotUsed', 'False positive')]
public static void DefaultDimensionView_OnInitialized(FormDataSource sender, FormDataSourceEventArgs e)
FormRun formRun = sender.formRun();
FormDataSource DefaultDimensionView_ds = formRun.dataSource(formDataSourceStr(CustOpenTrans, DefaultDimensionView));
FormStringControl defaultDimDisplay = formRun.design(0).controlName('DefaultDimensionView_DisplayValue');
DefaultDimensionView_ds.queryBuildDataSource().addLink(fieldnum(CustTrans, DefaultDimension),
fieldnum(DefaultDimensionView, defaultdimension));
DefaultDimensionView_ds.queryBuildDataSource().addRange((fieldnum(DefaultDimensionView, Name))).value(sysquery::value('Departements'));
Thank you.
