I have small confusion, I have same object in my local database & client’s server. Only difference is my system have office installed & client’s do not.
While compiling a table I am getting error on client’s server :Could not load the selected type library.
On my system I am able to compile the same object.
If the automation you’re using in your object is using is the automations to Office, then it needs to be installed both on your system (to compile) and on your clients. The Office automation is basically a piece of the Office program that you’re incorporating into your program. And unless the “piece” is present when running the object then you will get the above error.
