unhandled clr exception occurred?
I am getting this error when trying to post invoice proposal."unhandled clr exception occurred ". can you please tell me how to get rid of this error.
Please tell us (much) more about what you’re doing when you get the error.
The only advice I can give you so far is to catch the exception (if possible) and investigate it’s type, message, call stack etc.
Once do the Incremental CIL and check the same. (Just a work around)
Thankas it is working. I have one more issue. we recently upfraded to R2 from 2012. so when I try to open sales invoice report I am getting this error " Parameter ‘AX Partition Key’ does not exist on this report ". this partition key concept newly introduced in R2. can you please tell me how to resolve this?
Once try deleting the sales invoice report from Report server manager URL and re-deploy it.(Path: AOT\SSRS Reports\Reports\SalesInvoice)
will there be any issues or we have to take any pre-cautions before deleting sales invoice report from report server manager URL?
There will not be any issues as far as i know if you hold the development license. However I would suggest you to contact with your development team before doing that. Or else You can simply re-deploy and check without deleting from URL.
I tried with re-deploy so many times and restarted ax still it is not resolved
Sorry This is “unhandled clr exception occurred” not resolved. I did Incremental CIL, still getting same error
