Undo checkout
http://blog.slcconsulting.us/2013/06/objects-not-in-version-control-pre-2012/
I accidentally compiled the code, so it added all AOT elements in user layer to version control, and all the jobs, methods changed as uneditable.
How should I undo the checkout for all layers?
Thanks in advance.
Don’t you mean undoing the add operation, instead of undoing checkouts?
I would rollback the changeset through Team Explorer rather than AX.
Thanks, Martin Drab.
see in pending objects entire AOT got added…
See my jobs got changed like this, if i want to edit I need to do checkout this job
I tried rollback https://msdn.microsoft.com/en-us/library/aa882687(v=ax.50).aspx
there is no get option.
I need to undo all objects from version control.
I assume you didn’t follow my suggestion because you don’t know how. Here is some documentation: Roll back changesets.
