Unable to see custom d365 fo workflow in the workflow setup parameter
Hi ,
I have created custom workflow using below link
After following this step still I am unable to see my custom workflow name in workflow setup form.
Please advice, done full model and syc…still workflow button on form and in workflow setup level workflow button and custom workflow name is not visible
Did you get the solution for this ? I am also facing the same issue .
