Unable to open Ax 3.0 in windows 7
hi all
the following error is coming
no navision axapta clinet aos is configure using this setting
regards,
Shailesh
Have you checked with axc file whether that is correct or not.
I believe Win 7 must be supporting ax 3.0 verison.
Pranav…
Hi Shailesh,
Check whether client configuration details in AX configuration utility is correct. Most likely this will be incorrect.
Hi Harish,
the configuration is correct , the same configuration is working in server, but not working in client.
Shailesh
Hi Shailesh,
Are you able to ping AOS server? Are there any firewalls between client and AOS?
yes AOS server is pinging from client. and i have already off the windows firewall.
