I have facing problem during I click on user options file. An error prompt as below: -
A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and the SQL Server is configured to allow remote connections. (provider: SQL Network Interfaces, error: 26 - Error locating Server/ Instance Specified)
Enclosed herewith the path: \System Administration> Common> Users> users> select action pane> Options
Any advise?
Thanks & Regards.
