Unable to create credit note !
When i am creating credit note , i am getting infolog saying “Line property is missing,update has been canceled”
though line property is having value callld " no charge" in dropdown.
Hi Satya,
In which (po/so) order your trying to create Credit note? Can you let me know what steps you have followed?
Sarathy
Hi Sarathy
Thanks for your reply.
The way i am doing is… PO form-> select one PO in header which is already invoiced->in Header functions->Create credit note->on the credit form uncheck Delete purchase lines->then selecting the matched PO and line as what i have in PO form then ok->after that am getting this infolog.
Hi Satya,
Is this PO is raised from Projects? If not, it should not give you that error. Can you share the screen shot?
Sarathy
