Created a report for barcode printing using automation variable. facing the above issue when running the report. what is missing?
Are you using a custom .dll? If so, it seems like you didn“t register your .dll (Class not registered), did you?
Thanks, Albert
The issue is cleared now. It seems something is missing when I registered the .dll, After registering the latest one it was working fine.
