I am in the UK and have a connection via terminal services to a US server running Navision US 3.70A. The database has 2 companies, 1 the US company, and the other the UK company. When I run reports I have to enter dates in the us format, i.e. MM/DD/YY. Is there a way I can use US Navision software using UK date format DD/MM/YY, while allowing my US colleagues to continue as normal.
hello Navicons, the date format is controlled by the regional settings in your terminal server session. Just go to control panel, regional settings, and change to Great Britain (or is it United Kingdom?) and the dates will come out the way you want it. //Pelle
Thanks Pelle. That works fine. Regards. Navicons.
